Documentation states that you should have an option to cancel a cache job in the Job Status pane. I do not have one; I'm assuming because publishing of the map service was completed successfully so it considers the job "done" even though the cache generation is still in progress. Is the only way to kill the caching process by going into server and killing the running instances on CachingControllers and CachingTools geoprocessing services (under the System folder)?
