Can The Color Of Vertices Be Changed in ArcGIS Pro?
1179
08-08-2018 09:10 AM
Mark_Hotz
Occasional Contributor II
I'm currently editing a map using ArcGIS Pro 2.2, but because the base map I'm using is predominantly green in this one area I'm finding it very difficult to see the vertices (because they're also green).
Is there a way to change the color if the vertices in ArcGIS Pro?
Thanks
MarkBockenhauer
Mark,
You can use symbol setting to place a marker on the vertices.
Add a marker layer
Then set up the marker symbol, choose the shape of your choice from a font.
Then set the Marker Placement to be 'On vertices'.
Whether editing a feature or not, you will be able to see where the vertices are.
Mark
DanPatterson_Retired
There doesn't seem to be a vertex properties option at all
Modify feature vertices—ArcGIS Pro | ArcGIS Desktop
Mark_Hotz
Dan:
Thanks...even though you could not find a solution, I'm finding comfort in the fact that my own research methods are probably not that bad :-).  I will use a work-around I guess (i.e. temporarily use a different base map while editing).
perfect solution
MarkBockenhauer
Mark,
Add a marker layer
Mark
Mark_Hotz
Mark:
Thanks a million.  I had an inkling that something like this should be achievable in ArcGIS Pro...never thought of looking there though.  Awesome solution...this will work well I'm sure.
