Can't Select Living Atlas Terrain Layers in ToC (ArcGIS Pro 2.3.2)
525
04-25-2019 10:28 AM
by Anonymous User
Not applicable
Hi All,
I just updated ArcGIS Pro to 2.3.2 and now I am having trouble selecting Living Atlas layers in the ToC. Each time I try to select the Terrain layer, for example, it automatically clears the selection. When I right click on the layer most of the menu options such as Symbology and Properties are grayed out. When I click on the color ramp for these layers in the ToC the selection is cleared and the Symbology pane goes blank. The problem only seems to occur on the Living Atlas layers I am using (Terrain, Terrain: Hillshade, and Terrain: Multi-Directional Hillshade).
Anyone else having this issue or know of a work around? It is very frustrating and never happened before I updated to 2.3.2. Thanks!
ThomasColson
Are you logged into Portal or AGOL? What type of licensing? Named user or concurrent? What license level? A video grab using https://getsharex.com/ will tell the whole story very quickly
