Can I Show Feature Data Set Name in Contents Panel
2248
04-09-2025 08:35 AM
Labels (2)
Frank_SA
Howdy,
Is there a way I can see the Feature Dataset name in the Data Source view of the Contents panel in ArcGIS Pro?
In ArcMap, you could see the Database, Feature Dataset (FDS), and Feature Class. This helped me find and organize features in a map without having to build bespoke groups of features.
Is there a way to toggle what is displayed in the Contents panel, particularly so I can see the Data Source view?
Screenshots of what is in arc map and missing in arc pro attached
Thanks!
Robert_LeClair
Esri Esteemed Contributor
There's an ENH-000162334 - "Add a way to turn on/ off layers in the Contents pane listed per feature dataset" that's listed "In Product Plan."
Additionally, the enhancement request says:  "In ArcMap when using the Table of Contents, List by data source option the users can turn on/off all the layers inside of a Feature Dataset. It would be really useful if that option gets added to ArcGIS Pro.  When a Feature dataset contains a lot of layers it is really useful to see that option. Additionally, there’s no way to see feature dataset groups in the ArcGIS Pro Contents pane yet."
Robert_LeClair
Frank_SA
Thanks!
Robert_LeClair
Certainly!  Glad I could assist!
