Can ArcGIS Pro 3.1 and 3.2 run on .NET 8?
534
06-17-2025 01:45 AM
ljlopez
Could you please confirm whether ArcGIS Pro 3.1 and 3.2 can run on a machine with .NET 8 (no .NET 6 installed)? Thanks
DanPatterson
From the archived help ....
This is the required version... anything beyond that is "inconsequential"
ArcGIS Pro 3.2 system requirements—ArcGIS Pro | Documentation
Software Minimum requirement
Microsoft .NET
Microsoft .NET Desktop Runtime 6.0.5 or a later patch release (6.0.6 and so on), using a Windows x64 installer, is required. The presence of Microsoft .NET Desktop Runtime 7 or later is inconsequential.
... sort of retired...
DanPatterson
Microsoft .NET
RichardDaniels
Honored Contributor
inconsequential means ArcGIS Pro 3.1. and 3.2 will not run without .Net Desktop Runtime 6.0.x. It ignores, does not use, .Net 8.
RichardDaniels
Honored Contributor
NO, you must have .Net Desktop Runtime 6.0.5 or later (in the .Net 6 family) loaded on your computer with ArcGIS Pro 3.1 and 3.2. ArcGIS Pro 3.3 was a breaking change when they moved to .Net Desktop Runtime 8.
