Calculation Rule FOR(VAR F IN .....)
751
02-28-2024 07:28 AM
Robswann
Can someone please help me with the following below, I am not sure what I am doing wrong, I have tested this in the arcade playground, but cant get it to work with my data.
I am trying pull data from a table and determine the percentage contacted
VAR Owners = FEATURESETBYNAME($DATASTORE,"Owners",["TractID","Contacted"])
VAR ID = $feature.TractID
VAR OwnerID = Filter(owners,"TractID=@ID")
VAR Cont = 0
VAR NCont =0
FOR(VAR F in OwnerID){
If(OwnerID[F] == 'Yes'){
Cont +=1}
If(OwnerID[F] == 'No'){
NCont +=1}
Return CONT/(Cont+NCont)
KenBuja
MVP Esteemed Contributor
Your loops (and you only need one instead of two) aren't getting the attribute from the feature correctly. It should be like this
var Owners = FEATURESETBYNAME($DATASTORE,"Owners",["TractID","Contacted"])
var ID = $feature.TractID
var OwnerID = Filter(Owners,"TractID=@ID")
var Cont = 0
var NCont =0
for(var f in OwnerID) {
  if(f.Contracted == 'Yes') {
    Cont +=1
  } else if(f.Contracted == 'No') {
    NCont +=1
if (Cont == 0 && NCont == 0) return null
return Cont/(Cont+NCont)
I also added a check to make sure you're not dividing by zero.
KenBuja
var Cont = 0
var NCont =0
    Cont +=1
    NCont +=1
Robswann
Thank you very much!
