Calculating Geometry in ArcGIS Pro extremely slow
6952
19
11-23-2021 06:34 AM
ABishop
Each time I attempt to calculate geometry for a feature class or shapefile, I experience extreme lag!  It doesn't matter if it is one record or 100 records... it is still slow.  Anybody else experiencing this?
Amanda Bishop, GISP
DanPatterson
MVP Esteemed Contributor
Forgot to mention  SDE is a whole other ball game.
If you are calculating using numeric data, NumPy.  I often find TableToNumPyArray, calculate in numpy, ExtendTable to get the results back in a new field, the fastest.  You could give that a try, I have old blogs on NumPy in the Python community
... sort of retired...
SteveKubera
Amanda, I'm having the same issue calculating geometry.  Just curious did you find a fix to this delay?
I am also using Pro 2.9...
ABishop
Hello Steve,
At the time of this post I was not able to resolve the issue, but now that I am in ArcGIS Pro 3.0.2, it seems to be much easier.
Amanda Bishop, GISP
GrantDickins_OX2
Hi. I am on 3.0.3 and I am having the same problem. A simple calculate geometry on 30 simple poly features (right click on the field and calculate geometry) takes 2-3 minutes to process (I just did this now with the same slow performance). It's been like that for 2 years lol...I'm just used to it. It seems to fluctuate in time taken sometimes quick but that is rare, but I have never found a pattern, cause or solution. All my data is local to the PC, data is clean, indexed, I've even regenerated the data, etc. Mostly no other issues to speak of but the calculate geometry is very slow to calculate.
ABishop
Hi Grant,
Where does your data reside? (i.e.. file geodatabase, SDE, shapefile, service?)
Amanda Bishop, GISP
GrantDickins_OX2
HI Amanda,
The data is mostly in (local) file GDBs but the same experience occurs with the few SHPs I have calculated on. I have compacted the GDBs and rebuilt feature class indexes over time, as well.
GrantDickins_OX2
For context, I should also add that I have had IT check the PC (high-spec, 2 years old) for any system issues, background app impacts, etc. and really nothing to speak of. I recall running the PAT tool about 18 months ago and all was green and within the limits easily. Thanks.
ABishop
Hello Grant,
You didn't mention your method.  Are you attempting the calculate geometry manually?  Have you tried any geoprocessing tools or a python script perhaps?
This one works well for me for version ArcGIS Pro 3.x
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-geometry-attribute...
Amanda Bishop, GISP
GrantDickins_OX2
Hi Amanda,
Yes, I have tried the GP tool - so both manually calculate (i.e. right click the attribute field header) and the GP tool, have the same result. I have not used Python directly - never attempted. For the former methods there is a lag in the process somewhere. Thanks.
Debert
I'm in 3.5.3 and experiencing the same terrible lag when attempting to Calculate Field. It takes me 2 hrs. to update one column for 10k features. 20k features failed. I'm unable to 'highlight' much more as once I try to change the table to the selection, it locks out and loads forever.
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
