calculate field add string multiple fields
5936
14
04-08-2021 01:24 PM
JaredPilbeam2
I used to be able to use Python and auto-fill fields by putting the string in quotes. For some reason it hasn't been working lately. I'm using Pro v. 2.7.2. The expression verifies and the there are no errors, but the (text) fields are not populated with the string? The field length is set at 300, more than enough.
JayantaPoddar
Please check if there are any undesired selected features in the input table? Ensure the table is not being edited by any other instance/application. Else reload the layer in ArcGIS Pro.
I am also using ArcGIS Pro 2.7.2, and adding an HTML path works just fine.
Think Location
JoeBorgione
What if you put an r in front of that statement like this:
r"https://blah/blah.blah/blah/blah.png"
I get it to work with or without the r which is basically short for 'raw' text so any escaped characters are taken literally: see this article for a more detailed explanation.
That should just about do it....
JaredPilbeam2
@JoeBorgione
It didn't hurt anything, but also didn't help.
Strange. It's such a simple thing that I've always been able to do. I've also tried the same expression on a different table that has a text field with the length set to 256, which is still more than enough.  It would not work either.
JayantaPoddar
Think Location
JaredPilbeam2
@JayantaPoddar
What's an example of an "undesired selected feature"?
JayantaPoddar
Any feature remained selected by mistake.
I guess that might not be the case.
You may try closing all ArcGIS Pro sessions > Open a new ArcGIS Pro session > Add the table > Calculate Field.
Let us know if this resolves the issue or not.
Think Location
JoeBorgione
@JayantaPoddar brings up a good point: is this feature published anywhere?  You'd need to shut down the service it is associated with if so...
JaredPilbeam2
@JoeBorgione @JayantaPoddar
Well,  I'm working on a hosted feature layer in Pro. So, yes, it's a published layer on AGOL. I'm signed in to my account in Pro and have added the hosted layer to the map via the Portal in the Catalog.
EDIT: I've since closed the browser which called the hosted layer then ran the field calculator again. No difference.
JayantaPoddar
Are you editing the hosted feature table? If not, you may remove it from the map.
Think Location
JoeBorgione
Hmm.  I just upgraded from 2.7.1 to 2.7.2 and grabbed a feature layer from my agol account; it all works for me. What I meant was if the feature you are editing is the source data for a published feature layer, like an enterprise gdb feature class that you published to a portal (including agol)
