CAD file(dwg) import into ArcGIS Pro
13592
12
02-27-2019 08:47 AM
KrisztianMartha
Hello! I am trying to import a CAD file which is in OS (OSGB36 coordinate system) into ArcGIS Pro. I could set the OSGB36 coordinate system (UK) for the database and for the base map(in the map properties) as well, but I cannot see my CAD objects when I import them into ArcGIS Pro. Also I cannot set the OSGB36 coordinates on the main map layout where the cursor coordinate visible. Could you help me what is the correct workflow for import a CAD file which is not in WGS84 or how can I set my project into another coordinate system? Many thanks
UPDATE: CAD file attached.
curtvprice
DA_BIM-GIS
Hello Krisztian ,
Would be possible for you to share the file with us ?
Best regards,
David
KrisztianMartha
Hi David,
The file attached.
Many thanks
