Is BUG-000103046 really fixed? I'm in Pro v. 3.5.2 and I can not add a locator to a project from an Enterprise Portal using the Catalog. I can navigate to the locator I want but when I click it it never loads. The one time I got it to show up in Catalog it was broke.
Instead of using the Catalog view/pane to add your locator, click the Insert tab, click Connections in the Project group and click Add Locator. Navigate to the location of the locator and add it. Do you get the same errors? Add locators to a project—ArcGIS Pro | Documentation
Thanks for the reply @Robert_LeClair ,
I can say that all of the locators but one can be added using that method. The one I have highlighted loads for five minutes, appears in the catalog for two seconds and then disappears. But, this locator does work as I've used it outside of Pro in a script. So, I'm not sure what the problem is.
Certainly - glad it worked out. Question then as the other ones work seamlessly and this one does not, when was it created and at what release of the software? I wonder if it's an old one that could be the case, maybe?
@Robert_LeClair
This locator originated in ArcMap 10.8.1. It's based on a field from our county-wide Address Points layer. It's updated weekly.
Perhaps this is the underlying issue then. Per this deprecation document - Geocoding Deprecation - it may be best going forward to rebuild the locator in ArcGIS Pro using the Create Locator GP tool to see if this makes any appreciable difference.Found this resource as well -
Signed in members can post, follow updates, and more. New here? Register a free account.
