BIM file to geodatabase crashing
802
01-27-2025 01:03 AM
dpsaltis
Dear Community,
I am trying to create a federated dataset through 10 revit files (4gb) using BIM file to Geodatabase.
I tried also from arcgis pro using toolbox and from arcpy using BIMFileToGeodatabase.
- ArcGIS pro is crashing and arcpy cycles through a never ending process.
Using only 2 or 3 revit files everything is fine.
Any suggestions?
Tags (3)
dpsaltis
Solved with a script using different approach.
gaofangwan
could you tell us what approach you use?
