Benefits of mobile vs. file geodatabases
4472
02-24-2023 08:48 AM
Bud
Esteemed Contributor
Mobile GDB:
One of the benefits I've found when using mobile geodatabases is that they're easy to share since they're just a single file. For example, I can easily attach a mobile geodatabase to an Esri support email -- without the file being blocked (i.e. a multi-file FGDB as a zip) or needing to deal with FTP.
File GDB:
Of course, a benefit to file geodatabases is that they're fast for spatial operations.
What are some other benefits/considerations when choosing mobile vs file gdbs for new projects/tasks? For example, mobile geodatabases have full SQL support, whereas file geodatabases do not.
jcarlson
MVP Esteemed Contributor
Under the hood, mobile geodatabases are SQLite, so there are plenty of non-Esri tools that can interact with them, no need to worry bout having FGDB drivers.
- Josh Carlson
Kendall County GIS
Bud
I think it was you that got me on to the Beekeeper SQL client a while ago, which can be used to query SQLite/mobile gdbs. Very handy. Whereas SQL clients aren't really an option for FGDBs, other than a couple of half solutions.
Bud
Benefits - Mobile geodatabases are stored in an SQLite database, giving them the following advantages:
  • SQLite is a widely available, stable, and trusted database.
  • SQLite is open source in the public domain, so no licensing is required.
  • SQLite databases are supported cross-platform and are stored in a single file on disk, making them portable and an efficient data exchange format.
  • SQLite is a full-featured relational database allowing for querying and reporting workflows and supports operations such as views and indexes.
  • SQLite is interoperable and is ubiquitous in mobile app development.
DamirCrnila
Is there any Esri mobile application (on mobile devices) we can use mobile geodatabases as a data store in the field?
