Basmap not Printing ArcGIS Pro 2.9.0
3915
7
12-15-2021 07:05 AM
JessicaJThompson
I am printing 2 tiles that are 36x82" directly from ArcGIS Pro. Everything except the basemap printed.
I cannot export to PDF or Image and print. This makes the files too large and the printing process crashes, I have tried a number of settings and options for over a week with pdfs and images, so I'd like to focus on why pro isn't printing the basemap.
Any assistance would be very welcome!!
All labels and features printed. Just the World Terrain Base basemap didn't.
Thank you for your input!
Cheers!
Jessica
DavidLombardo
This issue looks to be related to the scale ranges set for the base map. We need to adjust the scale ranges so the scale to which we have the base map set to is included.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/display-layers-at-certain-sca...
jcarlson
Is the base map coming from the older image tiles, or the newer vector tiles service? Also, what is the scale of the map? I've had issues getting vector tile services to print properly at large scales.
- Josh Carlson
Kendall County GIS
JessicaJThompson
It is an ESRI vector tile basemap at 1:275,000
Thank you for taking the time to help me sort this out.
JessicaJThompson
@jcarlson David from ESRI helped me find a solution, which may help you the next time!
DavidLombardo
JessicaJThompson
Thank you so much for your assistance and finding this little obscure source. It worked! I was able to print with the basemap!
DavidLombardo
Of course, glad we were able to find this to help you out!
JonBeets1
I know this post is old but I wanted to let everyone know that this solution fixed our same issue recently.
