Backup In Progress impeding work 2.9.2
16571
21
03-21-2022 04:07 PM
JonHoch
ArcPro has begun stalling while doing it's regular back up; I believe since I updated to 2.9.2.
The Help file mentions, "The backup process does not interrupt your work or slow down the performance of ArcGIS Pro", but I would beg to differ as I am reoccurringly in a stalled state of not being able to select layers and other functionality and get frustrated and look up and sure enough [Backup in progress].
The default was 5 minutes so I changed to 10minutes but it's still annoying that things pause every 10minutes to do a backup that isn't supposed to interrupt your work...
Anyone else with that issue?
DanPatterson
MVP Esteemed Contributor
Since the backup is limited in what it backs up...
Save a project—ArcGIS Pro | Documentation
The next time this happens, go to your project's backup folder (ie  C:\Path\To\Your\Project\.backup) and see what the size is.  You have to do this when the project is actually alive and running and slow.
... sort of retired...
KellyWright
Also having this issue; more prevalent when working via VPN. ArcGIS Pro becomes unresponsive and even though the project is only 2.8 MB it is taking upward of 5 minutes to "backup." I set the backup interval to 10 minutes and 5 minutes are being used every time. This is bordering on the ridiculous. Current version 2.9.2; no other performance issues over internet/intranet.
Apologies if I replied to the wrong message in thread.
SunniBoulton
I am experiencing exactly this problem, via VPN.  It IS ridiculous!!! So much time being wasted as Pro sits unresponsive
Robert_LeClair
Esri Esteemed Contributor
@SunniBoulton - sorry to hear you're experiencing this issue.  Besides what's offered in this community message, another option to consider is "exporting" your Pro project to a project package (*.ppkx) and import the package into a new project.  In the new project, turn off the backup and see if you still see the slowness / unresponsiveness.
CMV_Erik
I have the same issue in 2.9.1. I've been dealing with lags for a while in big projects, but I've only recently noticed the "Backup in Progress" message in the title bar. Since the backup essentially locks me out of the app while it's occurring, I think the backup frequency should be "x minutes from end of last backup" rather than "every x minutes"
mcguerd
Definitely notice a big slow down. I can move the screen around but not interact. Changed mine to 10 minutes and it seems a little better…at least I am not seeing the “backing up map” message at the top of the screen. Notice that there is also a lot of action with the ‘Microsoft Edge-viewer’  that is new on 2.9 as well although not too sure what it is doing.:kissing_cat_face:
JakeCoC
I upgraded to 3.0 and see this happening. I also noticed McAfee is simultaneously consuming a lot of resources.
by Anonymous User
Not applicable
I had to turn my backups off completely-- I couldn't save the project and couldn't do any work because 'a lock could not be obtained' on the mosaic dataset I was working with.
Lloyd_Moyo
Hello experiencing the same problem.How do i turn it off completely?
