Automate data extract from Map Service in ArcGIS Server Connection
977
09-13-2022 04:27 PM
Labels (2)
GISMac
Hi, I am wondering if it is possible to automate an AOI extract from an ArcGIS Server Connection Map Service which contains a bunch of Map Layers?
Ideally I would like to end up with a tool that does this automatically but a batch process now would be okay.
At the moment the only way I can extract the data is to import the data into a geodatabase then clip from there.
As a start is there a way to automate importing any Map Layers within a Map Service into a Geodatabase? For some reason I can do one at a time manually but as soon as I try and do multiple or batch it says it is not supported.
