Assign Label Color Using Arcade Expression in ArcGIS Pro
1452
02-20-2025 12:17 PM
MyEthiopia
Hi Everyone,
I used this arcade expression $feature.Name + TextFormatting.NewLine + "<CLR red = '255'>"+ $feature.Address +"</CLR>"
The issue is that some labels have the red color will others show the whole expression. I am lost on what could be the issue.
KenBuja
MVP Esteemed Contributor
The feature name contains special characters (& or <), which causes the formatting to fail. You have to replace those characters with their equivalent character codes (&amp; and &lt;)
replace($feature.Name, "&", "&amp;") + TextFormatting.NewLine + "<CLR red = '255'>"+ $feature.Address +"</CLR>"
KenBuja
MyEthiopia
Thank you, Ken!! This saved me so much headache. And it makes perfect sense
