Are licenses pro-rated?
1107
04-30-2023 04:31 PM
AdamFerrary
I'm self-employed (no employees) using ArcGIS Pro 3.1 here and there for landscaping projects.  I only need a Basic level license, which I can barely afford honestly. A client sent me a huge list of KMZ files that I have to import, but batch import is only included with a Standard level license, which costs 4 times as much as a basic license and more than the profit of the entire job.
If I upgrade to the standard license to do the batch import and then switch back to the Basic license, will my license cost be prorated? Or will I have to pay for a full year of the standard license even if I only used it for a few days? Anyone know?
I understand this is more of a customer service question and not a community question, but I thought I'd check with the real experts first.  Thanks!
Luke_Pinner
MVP Regular Contributor
Not an answer to the question as asked, but you may wish to consider expanding your toolkit...
Look at open-source options such as GDAL/OGR for commandline data conversion or QGIS for a full GIS suite.  Converting a bunch of KMZs to something ArcGIS can consume is pretty trivial.
ChristopherCounsell
MVP Frequent Contributor
Can you try this:
  1. Go to Tools
  2. Search for 'KML to Layer' but don't select it from the results
  3. Right-click it and select 'Batch'
  4. Follow the prompts to select your KML files.
  5. The output name will create the results with the %Name% being the input name of the KML files
I don't think you need a standard licence for this workflow
Robert_LeClair
Esri Esteemed Contributor
With regard to your question, no ArcGIS Pro licenses are not prorated to my knowledge.  Once you purchase a standard license, it's for the time period purchased or renewal period.
BarryNorthey
It's possible that you were looking at the Batch Import Data GP tool that is not available with a Basic license. Most system GP tools including the KML to Layer can be batched using the process as explained by magisian above. Tools with a built in iterator such as from a Model can't be batched as I recall. The KML to Layer tool has limitations when using a Basic license as explained in its Help.
