ArcPro custom Symbology/Style
1557
10-17-2023 12:55 PM
CidMko12
Hello and thank you for you time. I have gotten a request to specifically use the Homeland Security Working Group symbology going forward in a project. I am trying to create a Style that consists of the HSWG symbology to facilitate this. I was able to find the old .ttf file download that would have worked for ArcMap, however ArcPro does not use ttf files for symbology. How could I go about transferring this into a readable format for ArcPro? Below are the links to the file source and an old Esri documentation for how to use it in ArcMap.
Thank you for your time.
https://www.fgdc.gov/HSWG/index.html
https://support.esri.com/en-us/knowledge-base/how-to-use-the-homeland-security-working-group-fonts-i...
Tags (4)
AyanPalit
@CidMko12 Please download and review the styles at link below:
https://esri-styles.maps.arcgis.com/home/item.html?id=742307e28bb54413a3e07eefc9946986
Perhaps this is what you need!
Ayan Palit | Principal Consultant Esri
Sean_Wray
You should be able to create the style in ArcGIS Desktop. Then if it is saved to to a style file you can import that style file into ArcPro.
https://www.esri.com/arcgis-blog/products/mapping/mapping/importing-older-styles-into-arcgis-pro/
AyanPalit
SteveCole
Honored Contributor
NAPSIG is an organization focused on emergency management and they also have incident response symbol sets so this might be another option to check out.
https://www.arcgis.com/home/group.html?id=2d21503899714afe8769ceb946419f2a#overview
