ArcPro Change Length / Trim to Length tool no longer is accurate
1374
08-10-2022 11:50 AM
BrendonJoyce1
Hi all,
Recently in my line layers, my "Change Length" tool no longer gives me accurate numbers.
Example, if I create a line of 20 feet (using the distance option which works) then finish the sketch with two vertices, then I modify that line, choose Change Length, and change it to 10 feet, it now reduces the length to 3 feet.
If I did the same with 40 ft to 20 ft, it'd be 6 feet.
Is there some setting that got changed with ArcPro? I would love to not have to factory reset the program since I have done quite a bit of customization, but I may have to. This does not happen on people editing the same data on different machines either.
Version: ArcPro 2.9.2
Cheers
Scott_Harris
@BrendonJoyce1 Try making sure the map's Display Units match the Map Units:
DanPatterson
MVP Esteemed Contributor
What is the coordinate system of the data?  And is it a projected coordinate system?
... sort of retired...
Scott_Harris
BrendonJoyce1
Thank you @DanPatterson and @Scott_Harris , I am in UTM and had changed the display units to decimal degrees in order to spot check some lat longs I was applying to fire hydrants to give to a department.
Simply changing the dropdown has it back to normal.
Cheers!
