Good morning all,
Im running analysis where i would normally make feature classes into a local fgdb, but since I upgraded to 2.3.2 just a few mins ago, it's only wanting to export shapefiles.
any clue why? is it a bug?
destination is a fgdb located on a network drive. This fgdb was originally made in arc9 or 10.
Previous versions of arcpro (before 2.3.2, i was on pro2.2) allowed me to export results to it.
in pro 2.3.2, it wont.
i made a scratch fgdb from arcpro2.3.2 in the same location, and it worked.
something changed in 2.3 or later that wont allow exporting to an 'old' fgdb.
It seems if i compact the old fgdb using pro2.3.2, it will allow exporting features to it.
I had previously compacted the fgdb using pro2.2.
so boys and girls, if you expect to export features to a fgdb in pro 2.3.2, compact your old fgdb, or otherwise it will try and export only as a shp file.
either that or im lost at sea.
What is the destination you are sending to? Have you confirmed it is a geodatabase and maybe not a folder with the same name as a gdb.
Have you tried sending results to another *.gdb?
Signed in members can post, follow updates, and more. New here? Register a free account.
