ArcGIS Pro Update (2.5.1) Partially Broke the Register with Geodatabase Tool
1442
05-12-2020 08:19 AM
RyanUthoff
MVP Regular Contributor
I have recently updated to the latest release of ArcGIS Pro (2.5.1) and it has partially broken the Register with Geodatabase tool.
While non-spatial tables continue to register fine, I am no longer able to register spatial tables with the geodatabase. I originally found this issue when attempting to use my Python script to register the tables, but I was also able to replicate this behavior when using the tool within ArcGIS Pro as well. I received two variations of the same error message, one through ArcGIS Pro, and one when my Python script fails. I've attached those error messages.
I reverted back to ArcGIS Pro 2.5 and the Register with Geodatabase tool works again (on the exact same table in the same database I was trying to previously register). I was able to replicate this behavior in two different environments as well. It looks like ArcGIS Pro 2.5.1 is a no go for us until this issue is resolved. The tables we are trying to register are within a Microsoft SQL database.
RyanUthoff
I opened a case with Esri support and they were able to replicate the issue and confirmed it is a software defect. For anyone else who encounters this bug, it is: BUG-000130888: Register with Geodatabase - Error 999999: Something unexpected caused the tool to fail.
George_Thompson
Esri Notable Contributor
I would recommend creating a technical support case to get a formal defect logged.
--- George T.
RyanUthoff
