ArcGIS Pro Topology Not Working
7597
12
09-12-2019 08:38 AM
MichaelSnook
I have been attempting to validate topology errors in the Pro Parcel Fabric (feature service) with little success.  I can see the errors and the potential fixes for them but when I select the appropriate fix nothing happens.  I have tried selecting from the right-click on the error inspector as well as the fix dialog with the same results.
I thought I'd test this out with a simple file geodatabase with just lines and polygons with a 'boundary must be covered by lines rule'.  When I attempt to create the topology via the wizard I get a ERROR 999999 message.
Any ideas here?  I'm submitting a bug as well.
Thanks!
Vanilla2020
I have the similar issue for ArcGIS Pro 3.12. I cannot select any specific errors in the error table through the Error Inspector window, I can only select the errors on the map. Does anyone have the similar issues?
AzizTejan-Jalloh
I am running into this issue on ArcGIS Pro 3.1.3.
AmirBar-Maor
The parcel fabric uses the standard geodatabase topology. If you see any bugs related to geodatabase topology like validation or error inspector please submit a case with technical support. You are welcome to DM me with your case number.
