Hello Esri Community,I need your assistance with ArcGIS Pro as I could not user the function "Table to Excel" when trying to export project. I am currently using ArcGIS Pro version 3.4 and getting the following error message:Error 000574: Python is not installed Error 000600: Cannot delete "the file path which is in OneDrive". It is being edited by the application.I have performed a clean reinstallation as suggested on this link, but the issue persists.reference: Install and Setup | ArcGIS API for Python | Esri DeveloperKindly advise on how I can resolve this. Thanks!
Hello @JoeyAbalos
It might be worth double-checking the Drivers you have installed, or may need to install.
https://pro.arcgis.com/en/pro-app/latest/help/data/excel/prepare-to-work-with-excel-in-arcgis-pro.htm
redirect the output to a local drive, not a Onedrive destination,
do the errors still appear?
Thanks for the response.I tried saving the file in C:\ drive but getting the same error message.
I did install the following MS Access Datable Engine 2016 Redistributable 64-bit driver and both .NET Desktop Runtime 32/64 bit. I still get the error message.I have attached the error message received.
How To: Perform an ArcGIS pro Soft Reset
How To: Perform a Clean Uninstall and Reinstall of ArcGIS Pro
or Tech Support are your options, especially the python not installed error suggests a larger issue is at hand
Hello Dan, I tried the above recommendations, but the issue persists. Unfortunately, tech support could not help with our case as we are a non-profit organization. If you have any other recommendations that I could try, I would very appreciate that. Thanks for all of yours inputs so far!
If you aren't working with onedrive and only have the version of python installed by Pro, then I am out of options (other than try another machine).
It is either your data or your installation. Sorry
It's not clear where the Calculate Field in your screenshot fits into the Table To Excel problem, but Calculate Field can use an Expression Type of Arcade rather than Python. Does that allow you to workaround the problem ?
