ArcGIS Pro Sketch Tools Keyboard Shortcuts
2220
09-06-2018 02:06 PM
CharlesBailey3
Am I missing something, or are the Pro sketch tools *really* lacking?Does anyone know any secret keyboard or otherwise shortcuts to split or reshape using freehand (preferably streaming if I dare ask) or to delete multiple vertices while editing the sketch? It really can't be overstated how helpful it would be if the sketch tools in ArcMap (which aren't perfect by any means) could be replicated in Pro. My users don't need 95% of the functionality in Pro but something simple like this will be a deal breaker for migration.
Robert_LeClair
Esri Esteemed Contributor
Charles - I don't see anything about the freehand construction tool for a Split function in AGP 2.2.2 nor is there an ArcGIS Idea for it.  But with regard to deleting multiple vertices at the same time - yes - with the vertex minus command, hold down your left mouse button and draw a freehand lasso around the vertices to delete.  Not exactly in the vein of while editing a sketch but it can be done.
CharlesBailey3
Yeah, thanks but the main application would be when you're sketching and
gone on the wrong track for 30 or 40 verts (or more), and want to get back
to the intersection of Wentright and Wentwrong - without starting over or
completing the sketch into some bizarre auto-complete nightmare which is
usually harder to fix than just starting over. But thanks for your reply.
Maybe the ESRI bots will pick it up Thanks, cob
DanPatterson_Retired
I always forget shortcuts... so I bookmark them
Keyboard shortcuts for editing—ArcGIS Pro | ArcGIS Desktop
Keyboard shortcuts for navigation—ArcGIS Pro | ArcGIS Desktop
Use ArcGIS Pro with a keyboard—ArcGIS Pro | ArcGIS Desktop
plus way more...
And I have probably missed the one you really want because I just used …. shortcuts …. and I only looked at the first page
JenniferCadkin
You mention two pieces of missing functionality.
1.  Split/Reshape with Freehand.
Streaming mode is planned for the 2.3 release.  Replace Sketch is planned for 2.3 as well.
2.  Delete multiple vertices while editing the sketch.
Mid-sketch, such as creating a new line, you can delete/move vertices without committing the sketch and switching to edit vertices.  Hover over the vertex and choose Delete from context menu or pick it up and move it.  It will be tedious if there are many but it is possible.  This has been in Pro since 1.0 and is not available in ArcMap; I am not familiar with how you were accomplishing this in ArcMap.
