ArcGIS Pro showing two different windows on the taskbar
2122
02-26-2025 01:29 PM
jahillganvar
In ArcGIS Pro 3.4, the taskbar is showing two different windows (project window and the map but separated-attached a pictured below) even though it's the same project. Whichever I click on, it opens the same thing (though in the previous version, clicking on the map used to open the map window only).
I never had this issue before version 3.3. I am on a tight schedule and this is both time consuming and bothersome. Is there a way to fix this?
jahillganvar
Apparently, the map window was fit to size between both catalog & contents pane and that was why there were two windows on the taskbar but the moment I let the catalog pane over the window it was fine. A docking issue I guess...
DanPatterson
MVP Esteemed Contributor
on the taskbar, try a right-click, unpin
then go to start, all programs, find ArcGIS Pro and repin it  to the taskbar
... sort of retired...
jahillganvar
It's not pinned to the taskbar. I did still try pinning and unpinning before but not working
DanPatterson
You should  report this since I don't see what you are seeing, so it may be something wih your environment or installation, and not common to all.
jahillganvar
