ArcGIS Pro- Map Series- Dynamic Leader Lines for Inset Map/Extent Indicator?
766
10-08-2024 12:24 PM
Amanda__Huber
MVP Regular Contributor
Hello ArcGIS Pro team and users-
We're looking for the leader lines to be dynamic in a map series when the extent indicator box moves around. Has anyone sucessfully used Inset leader lines in a Map Series? I haven't been able to find any resources out there for this behavior.
Amanda Huber
Amanda__Huber
After more testing we were able to find the answer to this-
When adding an inset map in a map series, a sublayer within your map will display, you will need to turn it on to view:
Here is where you can control the appearance of the indicator and the appearnce of the leader line as well.
Hope this helps if anyone stumbles across this.
Best,
Amanda Huber
Amanda__Huber
Best,
Amanda Huber
