ArcGIS Pro Locator fails with multipart lines feature class
502
08-24-2025 10:57 PM
GeeteshSingh07
This bug is reproduced at ArcGIS Pro 3.3.5.
Bug: BUG-000132982 for ArcGIS Pro
Similar Issue raised a long time ago: ArcGIS Pro Locator fails with multi-part lines - Esri Community
@ShanaBritt Any thoughts would be really helpful.
Best Regards,
Geetesh
geetesh486@gmail.com
DanielFox1
Hi @GeeteshSingh07
I would recommend getting in touch with your distributor and logging a support case to have this bug relogged or reopened if the issue can be reproduced, Please test at the latest version to confirm also.
GeeteshSingh07
Thank you for the recommendation. Unfortunately, we can't test in latest version as our upgrade is being restricted by client. However, we'll see what can be done next...
Best Regards,
Geetesh
ShanaBritt
@GeeteshSingh07 It would be helpful to have the data to understand what is going on with the data. Are you getting an error or warning in the Create Locator tool when building a locator with this line data? Are you not able to run the Multipart to Singlepart tool on the data, then build the locator?
Logging a ticket with Support would be your test option and to include the data.
GeeteshSingh07
Hi @ShanaBritt , thank you for taking out the time to check this.
  • We have multipart lines in the line feature class. When we use "Create Feature Locator" gp tool, it gives WARNING 003105: Record ObjectID = 10 from the 'Test_LineFC' input feature class has multipart geometry. Excluding it from the locator. Number of further occurrences: 24.
We just created test feature class & multipart features to test the issue...
  • Actually, we don't want to do that...as singlepart will split the geometry. This causes duplicate LocationIDs. When user searches LocationIDs, they'll see multiple addresses, giving poor user experience.
Best Regards,
Geetesh
