ArcGIS Pro: How to zoom to xy coordinates navigated by the “go to xy” tool?
6990
01-06-2022 01:40 PM
JamalNUMAN
Legendary Contributor
In ArcMap, there is “zoom to” tool by which one can navigate to “xy”
Jamal Numan
jcarlson
MVP Esteemed Contributor
I like the XY locator option best, but you can also use Go To XY, then just change your map's scale with the zoom scale selector, the "fixed zoom in/out" buttons, or just using the num pad's + and - keys.
- Josh Carlson
Kendall County GIS
Robert_LeClair
Esri Esteemed Contributor
Click the Locate command in the Inquiry group on the Map core tab.  In the Locate Pane, enter your coordinates and hit the Enter key.  In the results, right click on the XY provider results and select Zoom To.  That's one way.  In the the Go To XY, click the "hand" icon to pan to the location.
jcarlson
- Josh Carlson
Kendall County GIS
JamalNUMAN
Thank you guys for the help and the two workarounds.
  • It would be great if the “go to xy” tool can be enhanced to have the “zoom to” option
  • The “locate” tool has no option to plot the xy coordinate
  • Using the map scale makes it easier to zoom to the xy
Jamal Numan
JamalNUMAN
Please, vote:
ArcGIS Pro 2.8.4: Having an option to “zoom in” when working with “go to xy” tool,
Jamal Numan
