ArcGIS Pro: How to set the default unit for map to be in meter,
7109
28
02-08-2020 12:14 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to set the default unit for map to be in meter
Jamal Numan
JamalNUMAN
There should be a bug here! If you set them as “meter” and the Pro is closed and then open, the “meter” gets back to “foot” in its own. It doesn’t preserve the option set.
Jamal Numan
DanPatterson_Retired
works for me... no clue why it doesn't work for you
AhmadSALEH1
Hi Jamal,
I am using Pro 2.4, and I can setup the units to meters  even without changing the settings ( distance units, location units).
 and by the way, Ahmad SALEH‌ is my account not Saleh Ahmed. same for Rawan Saleh Not rawan saleh
Ahmad
JamalNUMAN
That’s for sure Ahmad. We can get the meter form the unit list in the Pro interface.
What I’m referring to here is that I need to get the meter selected by default without the need to select it manually form the list you are showing.
However, does your Pro keeps the meter setting from the option dialogue box such that the meter gets selected as new aprx is created?
Jamal Numan
AhmadSALEH1
OK I see what do you mean now.
I have the same behavior as you. when  I close  Pro after setting  the units to meters, the setting from the option dialogue box  reverts back to  foot when I open it again.
2.5, mine doesn't...
are you perhaps using basemaps in your default setup? or something other than a plain, no frills blank project?
AhmadSALEH1
- I am using AGOL basemaps, also I suspected that it might be Basemap related so I configured Pro to start with no basemaps but still got the same behavior.
- tried with "Blank Map template" and "start without a template". got the same behavior though.
something you use has "feet"
extension? addin? basemap? other additions?
Only you can track it down, all I know is that a clean 2.5 project with no fluff added keeps my units in meters (metres).
It is about time for spatial metrification as the default
BruceHarold
Hear hear.  Or in metric here here.  Or is that entendre entendre.
JamalNUMAN
Thank you Ahmad for confirming that you have the same issue. There should be a bug!
Here you go my settings, Dan:
Jamal Numan
