I'm using an AGOL based feature layer that has all its features stored as text. I want to use a query such as "Tot_Value >= 500000", however I get an error since Tot_Value is a text string. I recall an earlier version of ArcMap allowed this type of operation using the same data source, so I believe it can be done. I'm not a SQL expert, but assume I can cast this to an Int or similar, however a web search is coming up dry, and attempts on my part generate errors. Suggestions?
