ArcGIS Pro fails to publish web layer
12075
19
01-12-2022 11:16 PM
by Anonymous User
Not applicable
I am trying to publish a polygon layer from ArcGIS Pro to AGOL. However whatever I do, it brakes on 'Uploading service definition...', returns the message: 'Failed to publish web layer' and gives me the option to 'View log', which opens the log in txt format.
What could go wrong?
Thank you,
Stan
JayantaPoddar
Any useful message in the log? Please ensure you have the appropriate privileges to publish web layer(s) to your ArcGIS Online organizational account.
Think Location
SSMGroup
I just updated ArcPro to 2.9.1.
I'm currently trying to overwrite a web layer.  It has failed on me twice now.  And it currently appears to be stuck at "Uploading service definition"
I'll update this if it fails or completes successfully. EDIT: It's failed every time.
I reviewed the logs from my last failures... below are the messages it gives:
2022-01-13 08:36:07 Status: Failed ErrorMessage: Failed to publish web layer
Kanin
by Esri Contributor
Hello Stan,
I am sorry that you are experiencing this issue. Could you please check if your ArcGIS Online organization has enough credits? Speaking of which, how complex/large is the polygon layer you are publishing?
  • Is it detailed with many vertices?
  • Does it cover a large area e.g. census tract/district boundaries across an entire region/country?
Sometimes there are generic errors for larger datasets. Although this is not always the case, it's a good place to start.
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
SSMGroup
It appears others are having similar issues.
https://community.esri.com/t5/arcgis-online-questions/troubleshooting-process-for-uploading-to-arcgi...
I am the admin for my organization.   Plenty of credits, not an unusual task for me to perform.
It only includes 1 point feature class with 5 features, and 1 related table that doesn't have any records in it.
by Anonymous User
Not applicable
ArcGIS version is 2.8.0. I am publishing from the admin's account. Our organization has enough credits. The layer has 31 features. The level of details is low, because the polygons are either county or city boundaries.
last three rows marked as 'failed' from the log:
Test_Layer            25          WebFeatureLayer              Ceres Environmental Services, Inc.          https://www.arcgis.com/              ceres.admin      2022-01-13 09:46:00      Status: InProgress              StatusMessage: Publishing web layer failed (AGO)
Test_Layer             25          WebFeatureLayer              Ceres Environmental Services, Inc.          https://www.arcgis.com/              ceres.admin      2022-01-13 09:46:02      Status: InProgress              StatusMessage: Publishing tool execution failed
Test_Layer             25          WebFeatureLayer              Ceres Environmental Services, Inc.          https://www.arcgis.com/              ceres.admin      2022-01-13 09:46:05      Status: Failed              ErrorMessage: Failed to publish web layer
SSMGroup
Kanin,
I'm having the same publishing issues again.  Is Esri having issues again?
DonCavinessGeo
There must be an AGO issue. My office is having the same issues as listed above. We have more than enough credits, I'm an admin and I was able to publish on the morning of Jan 11, 2022. We can't publish last night or today.
DonCavinessGeo
Looks like it is working again! Thanks Esri!
SSMGroup
Are things working correctly for you today?  I'm having issues publishing again.
