ArcGIS Pro exporting EPS as bitmaps and not Vectors
10483
19
09-19-2018 08:01 AM
LouisHill1
I'm using ArcGIS Pro 2.2.2 to export my maps to EPS format and they are being rasterized.  I have 2 line features (no transparency) and 1 point feature (simple shape maker solid color, no transparency) that I am attempting to export. No background, no additional design elements, no basemap.
Share | Export | Layout | EPS
Line feature (3.0 thick, no transparency)
Line feature (1.5 thick, no transparency)
Point feature (simple shape marker, solid color, no outline, no transparency)
When I use Share|Export|Layout|EPS --> I get a rasterized set of bitmaps, or "banding".  These are strips of images and are not usable for what I am doing.
What I want is EPS vectors that I can control in either AI or Corel, preferably Corel.
I have used this export technique EXTENSIVELY in ArcGIS Desktop 10.X for years with success.
Anyone have any ideas?
PhilLarkin1
Did you delete this idea?
PhilLarkin1
I wasn't able to find your idea.
PhilLarkin1
Bump.
I've experienced this problem with Pro 2.7.1 and 2.7.3. EPS does not contain vectors.
JeffTorguson
ArcGIS Pro 2.8 does the same thing.
KariBuckvold
Holy cow, I can't believe this has been an issue for a couple years and not resolved.  Yes, this is how we create smaller sized .pdfs that can be easily emailed.  This is a major shortcoming!
blairtinker
I'm in 3.1.3 and this is still happening.  I have a layout with only 2 layers and some text graphics, no transparency on anything.  Whenever the point layer is on, the EPS converts to an image.  If I turn off the points the other layer and text exports fine as vectors.  I have tried all sorts of different point symbols, turned off outlines and halos, made as simple as possible but it converts to bitmap if that layer is on.   Book publisher requires cmyk eps files as vectors so I'm forced to jump through all sorts of hoops to get this.
JoeBryant1
I just get a generic "Failed to Export" message with no help topic link after a few minutes anytime I try to export to EPS in Pro 3.1.1. I have no points or text, just lines, polygons and a hillshade. I've tried clipping to graphics and image compression options, no change. Frustrating!
Amanda__Huber
MVP Regular Contributor
Hello ArcGIS Pro team,
Is there any update on this issue? Our team is also experiencing this.
From my understanding of the documentation, .EPS files should be able to be visualized as vector files but when exporting they appear as raster.
If someone could dig into this, that would be great st this seems to be an issue since 2018.
Best,
Amanda Huber
BrettFrahm
Hey Everyone,
Although it looks like some of you have noticed this behavior since before version 3 it was first logged with support on version 3.0.3. I have gotten the BUG information regarding this issue and I pasted it below. ESRI currently has it marked as "Under Consideration"
TypeStateBug NumberDescriptionStatusSeverityRelated CasesProductSubmittedLast UpdatedLabelsActions
  OpenBUG-000155360 A layout exported from ArcGIS Pro with Encapsulated PostScript (EPS) format has the elements within the map frame rasterized.Under Consideration Medium
ArcGIS Pro1/25/20231/25/2023
Bug Details
ArcGIS Pro
Product
3.0.3
Version
3.4
Last Version Reproduced
Windows OS
OS Name
11.0
OS Version
English - United States - (en-US)
OS Locale
Alternate Solution
Export the Layout as an SVG. When opening the exported SVG in an editing program like Adobe Illustrator, the contents of the map frame are vectorized if possible and elements are separated.
