Arcgis Pro convert contour lines meters to feet at regular intervals
3546
02-13-2023 02:47 PM
CharlescobBailey
I have a statewide contour line dataset (vector lines) that is in meters that I would like to convert to feet at regular intervals like 30 feet or so. Is there any way to do this with a math function, or will I have to go back to the DEM? Thanks, cob
AdrianWelsh
MVP Honored Contributor
Do you have physical contour lines at every 30 feet or so? Are are they at every meter? If I'm doing my math right, roughly every 9.144 meters is 30 feet, so it's likely that you do not have a physical line there. I am thinking that you might have to go back to the DEM and calculate based on foot-measurements.
DanPatterson
MVP Esteemed Contributor
The location of a 10 m vs 30 ft are close-ish, they will not be coincident.  I suspect that if you want nice round intervals in feet, then you will have to re-contour from the DEM.
... sort of retired...
