ArcGIS Pro Calculate Geometry
42345
23
01-08-2015 10:37 AM
DonovanCorliss
On my attribute table, I can calculate a field but I don't see the handy Calculate Geometry that I found in 10.2.2.
Do I need to go back to a script to add a Latitude and Longitude field in my attribute table?
I am using a File Geodatabase table in ArcGIS Pro 1.0 (Prerelease 2, Build 1692
JoshuaBixby
MVP Esteemed Contributor
Since the accepted answer was my answer, I went and added an update to state the OP's question about Calculate Geometry in ArcGIS Pro has been addressed.
ShailendraKomal
hi, im using ArcGisPro 3.5.2 - The Calculate Geometry tool runs, but does not display coordintaes in the x n y fields. ive checked all the prerequisites for using the tool and they are all inline - coordinate system etc...
the solution above adds new "point x and point Y fields" - this does not help in using an existing data set with and existing x y fields.
AyanPalit
@ShailendraKomal I added links to the Calculate Geometry Attributes as well as requirements of the field/data type for the geometry attributes. Check if you are using 'double' type for XY coordinates.
Ayan Palit | Principal Consultant Esri
AyanPalit
Updating this old thread for tracking and community documentation.
Use Calculate Geometry Attributes to add information to a feature's attribute fields representing the spatial or geometric characteristics and location of each feature, such as length or area and x-, y-, z-coordinates, and m-values.
  • Access the Calculate Geometry tool by opening the attribute table and right-clicking the field to bring up the context menu. There is an option to 'Calculate Geometry'.
  • This tool can also be accessed directly from the geoprocessing pane from within the Data Management toolbox > Calculate Geometry Attributes.
  • You can select an existing field or provide a new field name. If a new field name is provided, the field type is determined by the type of values that are written to the field.
  • Count attributes are written to long integer fields; area, length, and x-, y-, z-coordinate, and m-value attributes are written to double fields; and coordinate notations such as Degrees Minutes Seconds or MGRS are written to text fields.
Reference KB article: Calculate geometry in ArcGIS Pro
