ArcGIS Pro (3.6.0) Package Manager - Installing PDAL
2361
11-24-2025 08:51 AM
dgreenin
Good Morning,
I am interested in installing PDAL from the ArcGIS Pro (3.6.0) Package Manager by using 'Add Packages' within a clone of the default conda environment (arcgispro-py3).
However, the installation fails due to dependency issues.
Please advise.
Reference Documentation:
https://pdal.org/en/2.9.2/
"PDAL is a C++ library for translating and manipulating point cloud data. It is very much like the GDAL library which handles raster and vector data."
DanPatterson
from Download — Point Data Abstraction Library (PDAL)
It is strongly recommended that you make use of Conda’s environment management system and install PDAL in a separate environment (i.e., not the base environment). Instructions can be found on the Conda website.
and I wouldn't use a clone of arcgispro-py3, but create a separate environment because PDAL is only available on the conda-forge site and not the main channel.
When you create your environment I suspect python 3.13 should be the python version, then you can use
conda install conda-forge::python-pdal
as suggested in the forge site
Python Pdal | Anaconda.org
... sort of retired...
dgreenin
@DanPatterson,
Thank you for your response!
I have not had success in utilizing a seperate environment (not cloning arcgispro-py3) within ArcGIS Pro.
Ultimately, I am interested in using PDAL within ArcGIS Pro Notebooks while also be able to call geoprocessing tools, geodatabases, arcpy, Python API etc.
DanPatterson
Well, that leaves you cloning the arcgispro-py3 environment and trying
conda install -c conda-forge python-pdal --no-pin
to install from the conda-forge channel but ignore any pinned requirements.  It might work, and if doesn't, just remove the arcgis-pro clone
