ArcGIS Pro 3.4.2: Clicking the Georeferencing button causes the imagery to disappear,
1055
12
05-03-2025 08:38 AM
JamalNUMAN
Legendary Contributor
In the screenshots below, I couldn’t figure out why clicking the Georeferencing button causes the imagery to disappear. The “Zoom to Layer” option fails to bring the imagery back into view.
What could be the issue here?
The imagery is attached
Jamal Numan
DanPatterson
MVP Esteemed Contributor
add the data you want to georeference to first might do the trick
Overview of georeferencing—ArcGIS Pro | Documentation
... sort of retired...
JamalNUMAN
Not sure what do you mean by "add the data you want to georeference to first"
Jamal Numan
DanPatterson
you need known locations to reference your image to, that is, "control points"
You might want to read up on the process in the help files
JamalNUMAN
Hi Dan,
The issue here is that once the “Georeference” button is clicked, the imagery disappears before starting to work with the control points and cannot be zoomed to using the “Zoom to Layer” option. How can simply clicking the “Georeference” button cause the imagery to disappear?
Jamal Numan
DanPatterson
In your first image, you had an empty map with just an image and undoubtedly not coordinate system, that was probably the vanishing issue.
Did you follow the steps here then "fit to display"
Georeference a raster to a referenced layer—ArcGIS Pro | Documentation
JamalNUMAN
Setting the coordinate system of the imagery to “Unknown” appears to resolve the issue where clicking the “Georeference” button no longer causes the imagery to disappear.
The data is attached
Jamal Numan
AlfredBaldenweck
MVP Regular Contributor
If the image has not been georeferenced yet, it's floating around somewhere, typically in the middle of the Atlantic Ocean.
Like Dan says, you should add in the data you want to tie your image to, e.g. country boundaries or roads or even other imagery.
Then, after pressing "Georeference", move your camera to the rough location of where the image should go and hit "Fit to Display". This will bring it into view again. Then you can start georeferencing.
JamalNUMAN
Thanks, Alfred Baldenweck.
The issue was that once the “Georeference” button is clicked, the imagery disappears, and you're not given the option to perform the georeferencing steps.
Jamal Numan
DanPatterson
add the layer you are going to georeference to... then the un registered image, like the help says.
It won't display since it doesn't know how to display
