ArcGIS Pro 3.4.2 After Joining A Table - Failed to Open Table
189
02-13-2025 09:27 AM
KatyMooreFreeman
Updated to latest version and now I cannot open attribute table for a shapefile after joining a Zonal Statistic as Table output. I get the "Failed to open table. An invalid SQL statement was used" error. I can use the same shapefile and table in an older version and it works fine. Table and shapefile are stored locally.
DanPatterson
MVP Esteemed Contributor
Use Copy Features to make a copy of the shapefile into a locally stored geodatabase featureclass.  Try the join then.  If it works it may be a recent bug
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
Another thing to examine is see if any of the field names have a space in them.  This will throw this type of error too.
