ArcGIS Pro 3.0 feature rename taking really long time
4072
10
06-28-2022 11:03 AM
ThomasHoman
Hi All,
I recently updated to Pro 3.0 and was noticing some odd/slow behavior so was curious if others were seeing it. I am running Pro 3.0 on Windows11
A received a gdb and needed to rename some of the features. The dataset is stored on our local network share. If I rename the feature in ArcMap 10.8.1 the change takes 2-3 seconds. Pro 2.9.3 takes about 20 seconds. In Pro 3 the same rename can take up to 3 minutes.
Has anyone else observed this behavior?
Thanks for any feedback
Tom
miketribe
Yes, 3.0 is slow for basic functions.
tslack
Same issue here and it often locks up the entire document so I can't do anything else. Eventually it finishes but it takes way too long.
miketribe
On 3.1 and it's painfully slow to do anything...
Probably have to disable everything again like stupid indexing...
JamiePetersen
I found this thread and disabled indexing.  This worked for me.
Matt-Huser
I'm on 3.1.1 and it is still extremely slow for a rename. I hate to constantly compare ArcMap/Catalog to ArcGIS Pro but the old software was near instantaneous for this simple activity....
AmberConverse
I am using 3.1.3 and also have been annoyed at the slowness for renaming features.  I often just Desktop for these sort of changes (e.g. renaming lots of features, basic editing) and only use Pro when I need to reference streaming data.  I would love to have Pro be faster for basic operations.
JamiePetersen
@AmberConverse you should try disabling the local indexing to see if that makes a difference for you.  It was immediately faster to rename after doing so.
AmberConverse
@JamiePetersen sadly, I've already done this.  And it is still slow for me relative to desktop.  Sigh.
MohamedSadiq_C_C_
Sadly, for 3.2 also same issue...renaming and adding CAD files takes way too long. really su..s
