Arcgis Pro 2 is not opening
11490
26
11-23-2017 11:53 PM
GokulAnand2
Arcgis pro is not opening in my HP workstation z440 with windows 7. It was working flawless few days back suddenly it is showing nothing on opening just the loading circle is visible and similarly behaves the arcgis earth, and the arcmap works really fine. I think the problem is with only the ESRI apps.
Tags (1)
GokulAnand2
Thanks all for helping me out.,The issue happened I believe because of the .NET framework. repaired the .Net framework and solved the issue.
ArmandGerstenberger
Among the myriad of other issues I am having with ARC GIS pro 2, now when the program is minimized or put behind another window, the program becomes inaccessible- can't maximize it and windows explorer says its still responding. Not dealing with a lot of data here either.
DanPatterson_Retired
You might want to consider upgrading your machine, especially Windows 7
ArmandGerstenberger
I have windows 10 running on a 1TB M.2 drive, with 64 GB of DDR4 RAM @ 3000MHZ, a Ryzen 1800X @ 4GHZ, and two NVIDIA GTX 1080 GPUs. What is it I should upgrade? Should I install a floppy drive?
That might be useful... but I was referring to original poster and tagged you by mistake.
If you ran the Check your system requirements' mid-way down that page you should be good.
I have never experienced your particular issue, which suggests that it is either an environment setting that you have or you are working in a restricted environment and/or you lack full admin privileges.
On second thought, swap out the floppy for some extra monitors
ArmandGerstenberger
haha.. I'm maxed out on monitors. It looks like an NSA surveillance center here minus the floppy drives they probably still use.
ThomasColson
This would compel me to go to the UC, if some enterprising Professor had his students set up some GIS feature class that contained the "notes" for the song, and played a map tour of Africa....
The Floppotron: Toto - Africa - YouTube
