Hello, I upgraded ArcGIS Pro to version 2.8 because there were a couple of things I thought weren't working correctly or were not working in the older version. I seem to have the same issues with 2.8. When I try to reorder anything in the Contents pane in List by Drawing Order view it crashes. It also crashes when I try to drag a layer into the map from the Catalog and I always need to use the Add Data button. Do these things just work differently than they did in ArcMap, or is this a bug either in ArcGIS Pro or in my installation of it?
