ArcGIS Pro 2.8.4: A model builder tool fails to respect the scratch workspace environment and ends up with an error,
1554
10
08-01-2022 11:08 PM
JamalNUMAN
Legendary Contributor
Despite the fact that the scratch workspace environment is set properly, the marked tool in the screenshot below fails to respect this scratch workspace and ends up with an error. The “validate” tool is performed with no luck to resolve the issue
What could be the issue here?
Jamal Numan
DanPatterson
MVP Esteemed Contributor
From
Select (Analysis)—ArcGIS Pro | Documentation
the scratch workspace and the scratch folder are not supported environment parameters in a model or via python
Scratch Workspace (Environment setting)—ArcGIS Pro | Documentation
... sort of retired...
JamalNUMAN
They are
Jamal Numan
DanPatterson
Not all tools support all environments.  Check the bottom of the link I posted for the "Select" tool
Brian_Wilson
Honored Contributor
Be prepared for the fact that the workspace and scratch workspace settings might be ignored by any given tool and just work around it.
That documentation is wrong because the code is buggy.  Just how it is.
JamalNUMAN
This needs to be highlighted to esri as an idea for enhancement. The “scratch workspace environment" is supposed to be respected by all model builder tools anyway
Jamal Numan
JamalNUMAN
Please, vote:
ArcGIS Pro 2.8.4: Enhancing the Pro to make sure that all model builder tools respect the “scratch w...
Jamal Numan
JamalNUMAN
The issue persists to exist even in the Pro 3.1.5
The model builder tool does not respect the “scratch workspace” set in the environment
Jamal Numan
JamalNUMAN
The issue of scratch workspace environment, extent, and mask persists to exist even in Pro 3.1.5
Jamal Numan
DanPatterson
I can't find anything on the public facing Tech Support site, perhaps it hasn't been reported by anyone if it is widespread and not just in your situation.
