ArcGIS Pro 2.6: How to identify which band is which?
3402
5
08-17-2020 03:10 AM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, the raster has 4 bands. How to identify which band is blue, red, green, infrared, etc.?
Jamal Numan
DanPatterson
NDVI—ArcGIS Pro | Documentation
raster
The input raster.
Raster
nir_band_id
The band ID of the near-infrared band. The ID index uses one-based indexing.
(The default value is 4)
Integer
red_band_id
The band ID of the red-edge band. The ID index uses one-based indexing.
(The default value is 3)
So unless you have changed how the rasters are ordered, then by convention, nir would be 4 and red would be 3
... sort of retired...
JamalNUMAN
Thanks Dan.
As bands are labeled with band#0, band#1, band#2 & band#3, then is it assumed that they are equivalent to band#1, band#2, band#3 & band#4 respectively?
Is there any other way to check which is which so that we can make sure that (in my raster):
band#2 = Red
band#3= Infrared
Jamal Numan
DanPatterson
There is no band 0 in remote sensing, that image is just showing 0-based numbering... so add 1 to get your bands
JamalNUMAN
But what the values of RGB represent in the screenshot below?
Jamal Numan
JamalNUMAN
From the symbology, the bands representing the RGB channels are set. For example, in the screenshot below, Red is assigned to Band 4, Green to Band 5, and Blue to Band 7.
Additionally, the datasheet of the imagery should indicate what each band represents
Jamal Numan
