When in the Edith tab in ArcGIS Pro 2.1, with the tool Move selected, if I click on a point feature and move it, it moves all overlapping point features at the same time! I would like to only move one point feature, one by one.
The left-hand pane do show just one feature in the selected list but it still moves all overlapping points...
How can I change this behaviour? (no Topology is needed neither enabled).
It seems that one of two things is happening here...
Try selecting the point in the table first to see if you can isolate it and perhaps then....
Move a feature to specified location—ArcGIS Pro | ArcGIS Desktop
Thanks. This is exactly what I was trying when you replied.
Unfortunately, even selecting a single row in the Attribute table ends up to move both Point features, as shown below. Crazy!
Vincent:
Is the original workflow for moving a single point how you would perform this action for moving a point in ArcMap? If not, then this should be on ESRI's list to make ArcGIS Pro equivalent to ArcMap.
In ArcMap, for editing symbols in maps, I used to convert features to graphics or into an Annotation Feature Class. It worked well and it was faster. In another post:
https://community.esri.com/thread/203822-arcgis-pro-20-how-to-author-map-symbols
ESRI recommended to make a copy a symbols to edit to perform editing. I am not quite convinced with this workflow but this is all I could do in Pro for the time being...
But I discovered you cannot move an isolated point feature without moving all others overlapping points!
Thanks.
The issue was indeed the topology. Solution 1 suggested worked. I can now move feature points one by one with No Topology selected in Edit tab, under Manage Edits group.
Although the issue in this thread is now solved, I do have one additional question.
I discovered that Editing with Map Topology enabled (default), moving symbols is far slower than Editing with No Topology! A lot more slower!
But in the other hand, Editing with no Topology do not keep the symbol size according to the Reference Scale, with in turn is rather annoying (illustrated below). Is there any way to apply Reference Scale to symbols when Editing with No Topology?
Editing with Map Topology (symbol size correct according to Reference Scale):
Editing with No Topology (symbol size reduced and to to scale)
Thank you JohnJones! This issue was driving me bonkers. It was the "Map Topology" drop down.
I tried to repro this in 2.2: I moved 5 points all on top of each other, selected them, Right Click Only Select This, Modify, Move, and it only moved 1 out of the 5 points. Additionally, if I just click on the point, it only moves the "top" one. I would try upgrading to 2.2....
