ArcGIS 3.7 - Staging failed error when publishing web layer
928
5
05-29-2026 07:41 AM
AshleyHuntley1
I am trying to publish a web layer after installing 3.7 and I keep getting a staging failed error. I have attempted to address the issues that appear in the log (attached) but I haven't had any luck.
For the consolidation error, I double checked the sources for each layer and all of them are linked correctly. For Error 004017, I cut down our naming convention to the barest minimum and I receive that error regardless of the pathname length.
Is anyone experiencing this issue or had success resolving it?
Thanks in advance.
Robert_LeClair
Esri Esteemed Contributor
In reviewing Esri Support cases, there was a recent case using ArcGIS Pro 3.7 where there was an incompatibiilty issue with an Xtools Pro Add-in.  Do you have XTools installed by chance?  If so, disable it and try again.
Maybe related (maybe not):
ArcGIS Pro 3.7 Moves to .NET 10
001270: Consolidating the data failed.—ArcGIS Pro | Documentation
Robert_LeClair
AshleyHuntley1
Thank you so much! That worked.
BrianHall7
I disabled my XTools and still get the "Staging Failed" error.
MGT8C2U
I am having the same issue.  I disabled XTools Pro but still getting the "Staging Failed" error. Any updates to this?
MGT8C2U
UPDATE: I had to completely uninstall XToolsPro and now it is working.
