Arcade: track edits on a single field
1418
10-27-2022 09:50 AM
LyonMNGIS
Hello,
Can we track the edit date for a single field?
Background:
I have an address point layer with resident names.  I would like to track when the name of the resident is updated.  Essentially, what I would like to do is "If this field is updated then calculate the edit date in another field."
Thanks!
RhettZufelt
MVP Notable Contributor
An attribute rule on the edit date field similar to this should work:
if ($originalFeature.Name== $feature.Name)
   return $feature.Name
else
   return Now()
R_
RhettZufelt
else
   return Now()
R_
LyonMNGIS
Thank you for your help.  The script seems to work!
