An error when trying to use Create Building Scene Layer Content with Revit files.
2350
11-28-2022 02:17 AM
EdHixson
Hi there
I was wondering if anyone had come across this before (See below).
I am trying to bring a 3D revit model in a local scene (pulled from BIM) into ArcOnline. The base maps elevation is defined by using LIDAR data.
When I am trying to run the "Create Building Scene Layer Content" I get about 60% before running into a ERROR 999999. (Same error occures irrelevent of whether basemap in included or not)
If anyone had any insight or suggestions it would be amazing. Or if anyone needs more info let me know
All the best
-Ed
Tags (4)
Stefan_Thorn
Hi @EdHixson
i had this issue too lately. it seems the file path is to long in characters. if you save local it should not be problem.
Stefan_Thorn
Hi @EdHixson
EdHixson
Ahhh thank you, yep that worked thank you
RomainKahn
I still get the same error when I store the rvt file locally.
EdHixson
Hi Romain
The only advice I has is what was mentioned above. When you are saving it locally are you saving it not too many folders deep in your documents?
