Adding joins on multiple tables to a single table in Pro 3.1
2835
12-21-2023 10:59 AM
Jay_Gregory
I am running into a strange issue when I try to join multiple tables to a single base table.  I have 4 tables, all related to each other through a unique string column.  Table A is my "base" table.  I want to add joins for tables, B, C, and D to table A, and publish to AGOL.  I don't want to permanently join, just use the add join dialog.  There are a lot of similarly named fields in the tables, but also a good bit of different information.  And these are 1 to many or none relationships.
I can usually add two tables as joins (e.g. add joins for B and C to A, or D and B to A, etc.).  However, when I try to add the final join, Pro throws an error
arcgisscripting.ExecuteError: ERROR 001486: Cannot use fields from joined tables.
Failed to execute (AddJoin).
I really don't know what to make of this.  Anyone have experience or insight here?
Tags (4)
YiQiang2
I'm having exactly the same issue in Pro 3.3.2. Couldn't join multiple tables one by one. It was possible in 3.0
