Add Raster to Geopackage tool (ArcPro 3.3) stuck on 2% with Cached data
536
08-19-2024 08:28 AM
TomGlister
Issue running the 'Add Raster to GeoPackage' tool in ArcPro 3.3. Input raster is a 2.9gb cached tiled dataset. Tool starts and hits 2% and does not progress beyond even after 2 - 3 days.
Have tried to run the tool on a single tile (GeoTIFF) with the Google tiling scheme and the same happens.
Is anyone having the same issue? with this tool or any other?
Many thanks.
DanPatterson
MVP Esteemed Contributor
Is everything locally stored?
Anything particular in the tool parameters?
Add Raster to GeoPackage (Conversion)—ArcGIS Pro | Documentation
... sort of retired...
TomGlister
Everything is stored locally, all the parameters are completed. Thought it was possible to convert cached data to geopackage, however i'm starting to think that maybe it isnt possible. Also having issues converting a stacked mosaic dataset to geopackage. tool runs to completion creating a blank output, that covers the correct area of interest.
