Add data from A to Z to the Map Contents turns from Z to A Question
1031
03-03-2022 04:49 PM
DEAF_PROBERT_68
Honored Contributor
So when you add a lot of layers or imagery that you need to add to Map, so when you use  your mouse and use the shift to select multiple layers or photos.
Whenever I tried to start with Ascending and add them to Map, it doesn't ascend correctly.
When you the Add data, and you start to select from A to Z to the Map, the Layers would start from Z to A
Why does it do that ?
P.S. As of March 5, 20222 Finally got it up and running . Actually , was going to upload here, however, I could not for some reason...Found a way around to get it here...
https://drive.google.com/file/d/18QgnW-ALbXQiULQM6fS5zLJ9arVRSOri/view?usp=sharing
When you open it,  Be sure to change the Quality set to 1080 HD.  You will see better.  There is no audio at all . But I have a notepad open so Enjoy !
Thanks !
DEAF_PROBERT_68
Honored Contributor
So no one respond and thank you for that... I finally figured it out how to get them the sort in order from A to Z.
DEAF_PROBERT_68
Honored Contributor
I'll upload the video....
DEAF_PROBERT_68
Honored Contributor
I'm trying to upload my video and it is only 42 MB and won't let me to.  Any reason for that ?
DEAF_PROBERT_68
Honored Contributor
