3D Tileset Displays As Red In ArcGIS Online
1066
08-16-2024 08:56 AM
RolandDuhaime
I have a 3D tileset (based on PNG/JPEG files).  It displays as it should as a 3D Scene in ArcGIS Pro.
However, in ArcGIS Online, it renders as red. Any suggestions on any setting changes in ArcGIS Pro?  The tileset is created in the Data Interoperability Workbench.
Roland
Andrew--Johnson
Hi Roland,
Are you able to share the web layer or source dataset so we can debug further on our end?
thanks,
Andrew
RolandDuhaime
The zipped 54 meg tileset exceeds the 9 meg upload limit here roland@uri.edu.
ChristianStern
Hi together,
any updates on this issue? I've the same problem.
I am currently using ArcGIS Enterprise 11.3.
Best wishes
Christian
ChristianStern
I think I found the solution by myself. The SLPK-file was too old (version 1.7 instead of 1.9). I used i3s_converter  to update it.
Christian
